water/methanol injection
mopar_1974
Mankato, MN
just curious as to how many guys here have used it, what system was used and how well it works to stop pinging.
I have never used it on any of my cars but did use the Edelbrock Varajection on my tow vehicle back in the mid-80s and it worked surprisingly well (especially under load). It was adjustable from inisde the cab as well.
I use it on my Procharged Dart in place of trying to install an intercooler. I've never put an IAT on it to actually check temperatures. I bought a kit from the thesuperchargerstore.com bascially just a pump, one way valve, nozzle, and window switch to turn it on. I've had good luck with it. Normally I'm just running windshield washer fluid in it using the stock fluid reservoir but have ran distilled water/methanol
Are you going to be using this on a boosted engine or a high compression motor to run on pump gas?
