Water Pump
illrad91
sacramento
So i made the mistake of buying a wrong radiator. So I was wondering if I could buy a waterpump with the inlet on the driver side instead of passenger. It's a 1980 360 la. Does anyone have any suggestions on which one? Thank you
As said in your other thread, you'll need a '69 and earlier water pump and timing tab, and '69 and earlier pulley set.
Then you will have to re-mark TDC on your balancer since the mark will be about 90* off because you switched sides.
I still think you'll be time and money ahead to just get the right radiator.
Or.......remark your dampener with a timing tape...........or do what I do.....paint the timing marks/numbers on the dampener.
