Weiand stealth intake
I had a flat hood on my old 69 Dart and had no clearance issue. I did have to enlarge the ports to match the larger ports of the J heads. Iirc, they are cast for the smaller ports of the 318 heads.
Nice work; the engine bay looks sharp! I assume your fuel filter is tucked below the alternator? Did you use a 2 barrel steel fuel line and cut it by the heater hose attachment (since the 2 barrel steel line turns right there to connect to the front of the carb) and run a rubber line to the new carb?
I know the finned black wrinkle Mopar Performance air cleaner will rub the insulation with a Holley, Stealth, no spacer, GTS hood combo. That air cleaner has no drop at all.
Hi. Thanks guys.
Yes. found a fuelfilter with fittings 90gr apart. Super smoooth.
Did not know that the steeltube from the fuelpump and up behind the alter was for 2barrel.
And a short rubbertub did the final Connection.
This Winter i will uppgrade the fan with thermocoupler. Fanshroud. And maybe a original cooler.
Think they look much nicer but the aluis okey for now.
