weld through primer?
Dodgenut64
MO.
In the next week or two ill be welding back in a radiator support and was wondering if i should primer up were metal will be covered by metal (were the fenderwell attaches to the upper radiator support), even though it will be closed together with the spot welds. I thought i heard someone mention some weld through primer, does this tuff work? If not, what should i do about the bare metal that will be inclosed. will it be ok once the outside of the rad support if primered up? thanks
I've used weld through primer on the back side of panels or seams like you're talking about. I'm sure it will help protect from corrosion to some degree - just how effective it is, I don't know. I've found it a little harder to weld because it does generate spatter.
