What Brand Rear Sway Bar
340six
King Of Bling
New Orleans
Looks like Hellwig is $500.00 USD and has good reviews. But
what else is out there.
I used the Addco bar on Vixen. The mounting hardware though has been known to pull the U bolts through the frame rails on hard cornering, so you need to reinforce the frame rails in that area. I welded some steel plate to the bottom of my frame rails where the U bolts go through. It worked good.
I used the Helwig front bar and Addco rear bar on my wagon
Addco hardware is a little under-engineered. Hellwig makes good products — I would be inclined to go that way.
I have used Addco front and rear bars, and Hellwig front bars, BTW.
