What Headers fit best in Barracuda small block with powersteer
What year, looks like an early one. If it's 64-66, I recommend Doug's headers. 65'
BTW, early A body headers are expensive, hold onto your wallet! 65'
If there are significant differences between early and late Abody exhaust systems, this may not be helpful but I scored a pair of Doug's on an Autozone sale. With power steering/'73, they fit very well, only needed a minor dent near the steering box and a little to clear the torsion bar on the driver's side. IIRC, that's it.
thanks do you run a standard starter motor?
Hedman are hang low junk IMO
Run either Dougs or tti. Better fit with no tubes hanging under the steering linkage.
Run a mini starter, unless you want the gear reduction sound. I buy them at the boneyards on 1/2 off days. Some of the headers require it.
I'm running a mini starter too. Header clearance aside, it's cheap weight reduction. The stock starter has to weigh 2x what the mini starter does.
