Kevin Jonker
Hey folks, what is the diameter of the rod that you use to stick through the shifter when it is in neutral for adjusting the shifter linkage? Can't you use a certain size drill or allen wrench? I need to do this tommorrow as I lost 4th gear. Thanks Kevin
