what is the difference between a
The Dl2016 is the later model so to say and its designed to replace the cr2016 ......in a lot of places you wont find the cr2016 in stock anymore. Its an older one and the Dl2016 has more applications because it has a more consistent discharge pattern which will make it last longer in low drain devices.
