What master cylinder to use
girard,ohio
I have a 74 scamp with a built 360. im putting an 8.25 with a disc brake setup in and was wondering what master cylinder i should use instead of the stock one i have now. thanks again
first off, the search feature here is your freind, theres plenty of posts on this subject.
assuming you also have the front discs, you have a couple of options. you can either get a master thats specific for four wheel discs like this http://chucker54.stores.yahoo.net/24whdibrmacy.html, or you can use a stock disc/drum master, and either gut or eliminate the prop valve, and use an aftermarket adjustable prop valve from summit or other vendor. if you choose that path, its a much cleaner install by taking out the original prop valve and plumbing in an adjustable unit.
