What plug to use on a BB mopar
I run a 10
Thanks HOTMOPR , this is my setup 90% street use
- 514 ci
- 9.5 c/r
- 440 source alum. heads
- 640 115 solid roller
- pro comp intake
- 900 cfm C&S blow thru carb
- A1000 pump
- Garret 88mm w/ 1.39 ex.
- JE pistons
- Eagle H beam rods
- Eagle 8 bolt stroker crank
- MSD Dig 6al
- MSD crank trigger
- 50 - 150 shot of nitrous out of the hole at the track if needed
Trans
- 727 trans man. valve body
- 400 PTC conv.
Rearend
3.23 / 8 3/4
Strange 35 spline spool and axles
Drag radial 325
67 DART
- All steel with glass 5.5'' cowl hood
- mini tube
- SS springs
- 90 10 shocks
- 10 pl. cage
You won't need the nitrous. Chances are you won't hook with that chassis set up anyways. Cool car!
I guess I should have asked what 88 it is before I opened my grill. LOL I would run a 106 on it but some of the smaller turbos would work well also. I ran a 88 for a bit but I blew it. Not saying you will I had a lot of other things go bad at the same time.. like 7 pistons and that's what took out the turbo
I have a Garret T88 with T-6 ex. flange 1.39 A.R. , 5" V band ex.
The exhaust side on the big side is 109.8 and the smaller side is 100. 7 the inlet side on the bigger part of the finn is 117.57 and the smaller side is 85.95
Part # 23503264 serial # JIM71544
