Wheel bolt pattern
GRW
New Member
minnesota
What is the wheel bolt pattern of a 1972 Dart Swinger. I believe it is a 5X4" pattern, but that seems kind of small. I want to get some after market wheels for this car. Any help? Thank You
The 5 on 4" is correct for all models. They also use 7/16" studs. Wheel selection is limited but they're out there.
1972 was the last year for small (5x4) bolt pattern on an A body.
I have two new 15 x 8 inch Crager SS's but I am fairly sure that they are too wide for a Dart reguardless of the back spacing.
The 72 and earlier model years all had the 5x4 bolt pattern. 73 and later drum brake cars also had the 5x4 bolt pattern, too. All 73 and later disk brake cars had the 5x4½ pattern.
The Rallye wheel and poverty wheel are available new in the 5x4 pattern as well as the Cragar SS. Every now and then a used set of Ansen Sprint (alloy) wheels will turn up for sale on FABO or Ebay.
