Where can I find computer codes?
Tarr
I have a dak that has the code 12 flashing. Where can you get a copy of codes?
hit up google with all the info you have... 9 get you 10 something will pop up that will help. alot of the time you find a post from a site completely about your issue...
1986-95 cars, if it is the codes you get from hitting the key a couple times, the 12 code and the 55 code don't mean anything. Beginning and end codes. Donovans garage had code lists too I think.
Gary's site only has codes to do with the 2.2 & 2.5 cars to 93. code 55 is end of codes and 12 is no constant 12V, I think that those don't change untill 93. Some part stores read codes for free around here as long a you buy parts from them.
Good point about the key flash 3 times and it flashes the code and ends in 55.
