Where does this part go?
72Plymouth
Vista, CA
I have two of these and looked up the part number but didn't find anything yet. Anyone recognize it?
Thanks! Would you happen to know if it's the one that works with my '72? They were in the trunk when I got the car. I cant really tell if they are new or if someone saved old ones. The metal looks kinda old but the rubber bushing looks good.
They are new and will be fine in your 72
Thanks. Thought so because the rubber looks new. I'll check the ones on the car to see how those look. Is it possible to see the rubber part once they are on? Appreciate your guy's help.
According to napa's website yes that is the correct # for a 72 Scamp.
Pretty sure the lower control arm bushings were the same for quite a few years.
http://www.napaonline.com/Search/Results.aspx?Ntt=267-3193&Ntk=Keyword&N=599001+101972+50056+2056023
Have you checked on the condition of your bushings/suspension components?There's probably a reason these were purchased.
Thanks. Yeah there were a lot of parts in the trunk and not sure if some are new or not (reman carb, float, bushings, ignition coil, ballast resistor, etc.).
