Which media blaster?
sazzlefrats
Pleasanton, CA
http://sfbay.craigslist.org/nby/tls/3735099207.html
Harbor Freight, Red, 40lbs nominal, better water trap, fittings
http://sfbay.craigslist.org/pen/tls/3732127272.html
Soda blaster 15lb capacity, comes with 1/2 bag of medium soda material
http://sfbay.craigslist.org/sby/tls/3731330338.html
whatever commerical grade automotive sand blaster means, also has a air drier & ceramic tip
All are cheap
If you are not doing a lot of blasting, I bought one at Sears 50 pound and I did all my engine compartment with it did a great job has ceramic tip in it too and it's easy to move around
You'll go through 15 pounds of media in a couple minutes with any kind of decent air pressure so I'd avoid that second one like The Plague. Pot blasters like the other two usually work great but are kind of time consuming to fill due to the small opening. Is portability necessary for your needs or would you better off with a small cabinet? They're about the same price range and contain the mess without having to suit up, use a respirator, find a big box or tarp, sweep up and strain the leftovers, etc.
Get the biggest one you can afford... Cause like CudaChick said its a PITA to stop and refill a pressurized pot...And it takes a good size compressor to run one for very long.
