Which Pick up with 187 pan.
The 187 pan uses a pickup that is almost the same as the 70-71 hemi/6pk pan , it's just a little longer and can easily be made to work , add a windage tray and the 2 gaskets and and bend it a tad and you would be all set .
Can someone post a pic of correct pickup tube i have a 187 pan and 3 different pickup tubes i would like to know whick is correct for it. thanks
It's a straight tube , no bends except at the bottom where the pickup head is attached .
It's just a regular center sump pickup. Nuthin special at all.
