who can make custom aluminum shroud from my prints?
aengineguy
Mt. Zion, Illinois
I am needing a custom aluminum fan shroud. I am drawing it up in 3D and then will create the 2D prints from that. Any recommendations on an a guru that can make artwork from aluminum? ...or a company that specializes in custom aluminum fan shrouds?
A local welding shop should be able to tig one up for you.
Give young gun2.0,a P.M... He's pretty damn good,at fabrication..
If Younggun doesn't work out, Midwest Metalcraft in Windsor, Missouri does a lot of work for us. If it's a one-off with cosmetic welds indicated on print, they have their best welder do the work and he's very, very good. Teaches classes on welding and everything.
(660) 647-3167
Will do, thanks!
I bought the closet one for my needs, from summit. then reworked the h--- out of it to fit my rig. turned out pretty decent. comes apart in the middle on the sides like a 90 gm pick up. have to run a short oil filter tho.
