Who sells KH calipers 4"
pauls340
17 miles N of Detroit
Got a set of front disc brakes and went to the auto parts, they found KH calipers for $155 each ! They told me to rebuild it should be about the same, is that for real? Any suggestions? Thanks
calipersonline.com come with ss pistons and guaranteed for life.
I had almost as much in rebuilding mine as it cost to buy there's
Got my 2 sets from Rock Auto - right around $100 a set plus my cores
That's for real.
This is one of the reasons my car (factory KH Disc Brakes) was converted over to large bolt pattern.
LBP brake parts are easy to get and don't cost much.
Also.... My car sits allot... The KH set up does not like to sit (pistons stick). Make sure you get stainless pistons if you order new KN calipers.
I had both calipers rebuild for $80. They pretty much the same as a mid '60s mustang. If you need them sleeved it will cost a lot more (I was quoted about $140 per)...If you can't find a local rebuilder, rock auto or calipers online is probably the way to go..
