Wide Rims (Homemade)
Grampas Toy
ohio
More pictures continued!!!
pic.
#1 good flat work surface that`s 15/10,000ths. (don`t have to be that close)
#2 ripples from rolling,must be smoothed.
#3 4" skinny(V.W.)
#4 check stock wheel before anything
#5 compare stock run-out to tacked wheel
#6 wifes 5th avenue
#7 choose backspace it`s still very tight fit
#8 4" V.W. skinny
#9 where the centers are welded pick the shortest of the 8 grind other 7 to match
What I call determination, Let us know how they balance after all`s said and done.:idea1:
No offense but is that really safe to try and make your own rims?
None taken,, made some back 1986 mounted n-50s tire shop mounted &balanced them,,had them on 75 dart 6cyl. 80m.p.h. no vibration.6 was straining 3.23 posi certified pipe welder 30yrs. welded everthing from the crack of dawn to a broken heart..pipefitters local 162 dayton.. No shells to buy back then..I would sugest to buy some..that`s what i`am gonna do if i mak e any more
How much back space do you have on the rear wheels? What modifications that you made to your springs?
Thats another great home made project for me! I have 9 of those 4" wide sbp rims.
tubed (mini) Dart,,moved springs in,narrowed rear...The less back spacing,the more stress on bearing,and studs...
Don`t worry about the DOG...worry about the GUN!
My brother is a welder and has been since Led Zeplin was hot, and I would drive on anything he put together.
Especially if he followed the guidlins of what I wanted.
I kinda thought a welder (Most welders) just kinda stuck metal together by melting both peices till they merged.
But they can be a very picky and precise breed.
Welders are like any other skilled trade- some guys take pride in their work some don't.
"Welders are like whores- all they want is more heat, rod, and money"
(and yes, I'm a welder, among other things...)
Theres rod burners and then theres WELDERS....BIG difference!!
One of my best friends lives in Mesa.
He's an off roader like I am, but seems to have no interest in our hobby.:wack:
I agree! (money part) most pipe welders have to take welding test ,,,for every job..and their all different,, Once you pass the pull test,you have a job,but every weld you make in field..then it has to pass x-ray..that`s why most pipe welders are pre-madonnas...It`s not unusal for one to have 30 or 40 certifications...
Yep my bro is a welder and has tickets up the wazoo,enough so that now he is an inspector. And makes big $$...100K + if he stays local but much much more in the field.
