Will 73 Duster wheel well trim work?????
I think they are the same 1/4 panels and wheel openings. Only thing I can think of is mounting hole location could be off.
:cheers: Eric
I found some nos stuff and the guy said I would buy it at my own risk. No return. What do you think?? I called rick at Laysons and they have the front and not the rear until feb.
Well like I said the rear end should be the same. But I don't know if the front fenders are. I don't think they are but don't realy know.
The rear will work but the fronts won't. The Dart Sport front fender has a different cut at the rear of the wheel opening. It angles back instead of coming almost straight down like the Duster. Hope this helps.
Thanks Guys. I just did not want to be stuck with trim I cant use. Thanks again
