Will these work for my dart?
Danohano
New Member
Maple Ridge
New to the Dart world, and by reading the forums it seems everyone has a different combo or rims / tires with most people running two separate sizes.
I have a 1969 Dart 4 door custom. I also have a set of 14 inch steelies. Stock suspension and brakes etc. Can you tell me if I will run into any problems running a 225/70/R14?
  1. How wide are your wheels
  2. Will the 225s fit on a wheel that is too narrow safely
  3. Is the height of the tire significantly taller than your last tires that fit
  4. How much room do you have between the front of your existing tire and your lower fender lip. Turn the wheel lock to lock with 3 people in the front seat.
I have 205/70R 14 on stock 14 x 5.5 steel wheels on my 67 dart. I have plenty of clearance (3/4" to 1") bottom front lip to tire
