Will they fit?
azdurango
Member
Phoenix, AZ
Hey guy's, I have a 64 Valiant wagon that is upgraded to BBP and standard a-body 8 3/4 rear axle. I want to put some AR torq thrust originals on it.
They are 17x8 with a -0mm offset and a 4.5" backspace. Will these fit the vehicle ok?
What brakes did you use in the front? I would think that an 8" wheel in the front is a little wide. Tire size may dictate what wheels you need also.
I'm just using the late model factory disc brakes in the front. Also the car will be lowered slightly with low pro tires.
