Window felt- how to replace?
Viper21700
Aiken SC
Ok, Ive used the search function... cant find how to replace these.. Ive found where to get them, how much they cost, who makes the best ones. but no postings on actually how to replace them. I need to put new gaskets as well, but those are straightforward.
Anyone have a set of pictures showing how to remove and replace the felts?
66 A body Cuda btw if that matters
Search deeper. You can use soft side velcro, and home door seal.
they are clipped into slots in the door lip. You can use a small screw driver and separate the clip a bit to loosen and remove them. If you choose to wait until you get the replacements it will be obvious.
