cannucky
The Guy With No Birthday
Anybody using one of these blocks ? Which one and wheres the best place to buy? I think I want to use one with a small block stroker I'm planning but would like some feed back first
world products make blocks for big block, not small block.
Indy is carrying the 340r3 block. I believe this is the block your talking bout. It is still made by mopar I believe. It has MOPAR casting numbers in etc.
And the r3 is a perfect choice no matter what you want to do.
There is also the ritter xr1 block, although I haven't seen one of these yet.
http://www.hughesengines.com/TechArticles/smallblockfromritterracing.php
Those are all Mopar small blocks except of course the Ritter block.
Siamese bore blocks are still water blocks but water does not pass between the cylinders. You can run a much larger bore with this block, up to 4.22.
