[Found!] WTB: Blower motor switch and harness for '67 Barracuda
Capecodcuda
Cape Cod
I'm looking for a heater/blower motor switch for a '67 Barracuda- part # 2770360. It would be great if it has the short harness with connector attached. Please PM if you have this. Thanks.
Hey Capecodcuda,
Do you still have the original switch ??
If so, you may be able to refurb it.
Lift the two tabs holding the switch plate to the housing.
Inside you will see the switch rocker assembly.
Its probably full of 50 plus year old hardened grease which causes the problem.
Get some electric contact cleaner and flush the internals thoroughly.
Apply some dielectric grease , put the switch base back in place and fold the securing tabs back down.
This worked great for me and saved me from paying an exorbitant price (close to 200.00!! ) for a new one.
Hope this helps.
Cheers!!
Thanks for the input. Unfortunately, I don't have a proper original switch; the one I have is the wrong style for a '67 so I'm trying to correct that. I'll make note of your comments for future needs- thanks again!
