WTB: wheel dust caps
danmc77
Barto, PA
First, does anybody know if the dust caps that cover the spindle nut are the same size from year to year?
I need a set (2) that will fit 77 Cordoba rotors.
Thanks.
i ordered mine from rock auto. they come in those HELP brand packages that kragens and napa sells, so im sure they can get them for you if they dont already have them. but im not sure if they are the same year to year. you can probably look on rock auto and see if the part numbers are the same. its a little work, but it should verify what you want to know. good luck!
Thanks - I didn't even think to check the local auto stores, but now that you mention it, I do remember seeing those in the "Help" section.
