Hello all, I am looking at placing an order on some heads. I am unsure on which ones would be best for my build and would like some input.
the engine is as follows,
360 .30 over w/kb 107's (block not decked)
gonna guess at about 9.5 compression using thin gaskets
hughes cam 5660AS
.579 intake lift
.587 exhaust lift
256 deg. intake duration @.50
260 deg. exhaust duration @ .50
will be running an RPM Air Gap intake w/750 Mighty Demon
I have a 3600 - 3800 stall converter from CRT
running 4.10 gears & 26" tall tires
vehicle weight is about 3100lbs
I am looking at the indy X heads through hughes engines part# hug-20301-sp they are "super prepped"
but not sure if the edlebrock super prepped rpms would be a better choice part# hug-60779-scp
it see's the track about 80% of the time, tell me what you think, also if there is something in the build that should be changed let me know also.
THANKS TO ANYONE WHO HAS INPUT TO SHARE!!
hughes cam 5660AS
.579 intake lift
.587 exhaust lift
