68-GTS
Super " Senior " Member
Used Transgo for years but found the fine tuning was becoming more and more frequent.
The overlap or tie-up, even with correct clearances at times took hours to correct.
Started using Superior Shift kits and was totally impressed.
They seem to have the done their homework... BTW Superior is AKA Fairbanks.
The shifts are nice crisp at normal throttle not annoying in traffic by any means but when you stand on it you know you have a shift kit..
If you have the power you'll break the tires loose on the 2-3 shift.
http://www.oregonperformancetransmi...OD&Category_Code=727SK&Product_Code=SUP-10430
