gniknayrb18
i changed out the intake manifold and the carb and pvc and now my car runs like..$#*[email protected] kept messing with it and took the vacuum hose off the pcv and it runs great????what is going on
ok pulled the pcv out and capped the port on the carb and still running the same if i uncap the carb runs at high idle any ideas
If it runs better with it blocked off, reset the idle speed and mix screws for best idle and find out why the PCV is causing you issues. It's nothing more than a metered vacuum leak.
Not having any idea what you have for engine or initial timing, no telling what the root isuue is.
Ede carbs are very sensitive to fuel pressure, too much pressure more than 5 psi, will mess you up.
