turbomopar
Anybody have any pics or info on the hydraulic clutch set UPS the original Dakota master is angled where it bolt a to firewall
Nope they come in Dakotas the one I have it's pu out of a 98 Dakota I'm going to put it in my 73 duster
How to set up the hydraulic clutch on the ax15 5 speed that I'm going to put in my duster. Maybe a aftermarket master cylinder or just fabrication?
Ok thanks that makes since. I also have to figure out how to connect master to stock pedals and how long to make rod on pedal. And stuff like that so if anyone has done this swap any info would be helpful thanks.
gear ratios are 3.83, 2.33, 1.44, 1.00, 0.79Can you post a pic of the AX15 and list the gear ratios?
I found a 96 and down 5.2 5 speed truck at a u-pull, and they said $175 for trans, clutch, linkage, everything complete.
Hyro clutch m/c appeared to be mounted straight on that one.
Also interested in any trans mount and crossmember mods that may be necessary.
Thanks for the info what year Trans do you have?I have an ax15 in my dart, built everything myself. There is a lot of fab work involved including cutting a lot out of the floor.
I used an s10 master cylinder along with the factory dodge pedals. I used the stock Dakota slave cylinder at first but it wouldn't release the clutch enough. I had to change to a slave from a cummins truck, it works great.
So far, it's been a reliable transmission for cheap.
Pretty sure the v8 Dakotas had the nv3500 in them anybody else know for sure?
V8 Dakotas used an NV3500 or 3550
The AX15 was only found behind 4 cylinders and 6 cylinders.
4 cylinders got the AX-5, as i said the 4.0 jeep is the only one i know of that got the 15's
Actually the AX5 was only found in 4 Cylinder Jeeps, you won't find it in a Dakota because it was never offered in one.
The AX15 was found in the 2.5L Dakotas and 3.9L Dakotas, and apparently the 4.0L Jeeps.
interesting! never knew they would put the 2.5L in the daks, thats insane... I work mostly on the jeep side so the 15 is a 4.0L only. goo to know on the 15 in the dak behind the 2.5
