Valiantap6
Member
Hi, I'm new to forced induction and putting vortech v2 on 318 LA engine, what should I do to fuel system, fuel pump, fuel regulator and things etc, please help as I want to do as much as I can myself before starting engine
Turbo Encabulator?
I've not gone down that path, but I can't imagine why two pumps would be needed. What you will need is a pump that can supply more pressure than Max Boost + the carb's max inlet pressure at the GPH required. An EFI pump will handle the psi requirement (assuming less than ~35 psi of boost) and I would expect that it could handle the GPH requirement but I don't know that for sure. You'll also need an FPR that you can boost reference. Can mod a Holley by-passing type regulator to do that, but unless they offer such a critter it will be a simple pair of mods rather than an RTR off the shelf solution. I am using a by-passing type Holley on an NA engine and so far I'm not impressed. Might be the pump, but it's inconsistent about fuel pressure. I'd look at other offerings, perhaps Aeromotive or SX?Doing vortech supercharger so will be doing blow through carb, I have heard people using 2 fuel pumps is there any need for that?
