Holy Roller
When putting a 383 in place of a 340, do I need to change the K member?
You need custom motor mounts.
rayer:rayer: gotta praise the discussion forum purist.OP didn't ask that ?
http://www.engine-swaps.com/So...which would be the easiest way to do this? Can I buy the mounts, shims and torque strap without having to do the cutting or drilling. And where's a good place to get everything from? Thank you everyone for the help.
stock K members require cutting/welding a relief for the oil pump.. Schumacher covers this in the swap motor mounts they sell..So...which would be the easiest way to do this? Can I buy the mounts, shims and torque strap without having to do the cutting or drilling. And where's a good place to get everything from? Thank you everyone for the help.
Easiest would be to beg Jim lusk to build you one.
I would highly recommend an Alterktion lol. Just kidding! ;)
My QA1 came notched for the pump, I just ground the weld flat and repainted the spot.. no cutting or welding required..
Do the schumacher mounts work with the qa1 k member
For BB/RB swap purposes?
Mild threadjack, apologies.
I like that paintguy...easy, serviceable, cost efficient. Where do I get them from and will they work on a 68 barracuda?Later K Member with Schumacher Swap Kit. Ease of install, serviceable starter with header's still on. Simple, efficient, cost proven.
tpg
I bought the 383 before I bought the cuda. I wanted a 68 rr and when I got the cuda the 340 wasn't in it.Just noticed what you want to replace --- WHY go from the 340 to a 383
