Hi Guys,
I'm planning to build a 408 stroker with stock heads and stock rockers for my 1974 scamp (similar to this one: MRL Stock Rocker/Head 408)
and I'm not sure wich cam to use.
Im planning
1976 360 .030 over
Scat cast steel crank
Scat I-beam rods
Pistons +5cc
Edelbrock Air gap intake
Windage tray
Home ported stock 596 heads 1.88 intake 1.60 exhaust valves
Stock rockers
Compression min. 10.5:1
I have a 650cfm holley dp carb but i think it would ve to small
Built 904 transmission with reverse full manual vb
Stock converter
8 3/4 3.23 sure grip
What do you guys think about this:
https://m.summitracing.com/parts/cca-k20-225-4
Im planning
1976 360 .030 over
Scat I-beam rods
Pistons +5cc
Windage tray
Stock rockers
Stock converter
