dibbons
I know they have some common parts.
The early ones were the 8 bolt flange, right?62-66 Poly cranks fit no problem and they are forged as well. 61 and earlier do not due to the extended flange. I guess if you used an adapter such as for the Gen I Hemi early poly cranks "might" fit.
I believe you are correct!The early ones were the 8 bolt flange, right?
