Do you think this will buff out?
Frankie
Member #9641
Heart of Georgia
Pulled the Slant 6 from my 71 Swinger. The seller said that #6 was a little low on compression. lol
I have a 318, and everything necessary to do the swap. I think. Engine, trans, motor mounts, V8 K member, rear trans mount, and torsion bars, V8 ignition and distributor, drive shaft, radiator...
It's been a few decades since I've swapped a /6 for a V8... Have I forgotten anything?
..little hole like that - what's the problem!?? :lol: - these days you don't need to swap the K frame - I think it's Schumacher that makes conversion engine mounts, and those /6 torsion bars are fine too (well, I guess they could be "tired" and need to be replaced anyway..)
A body Exhaust manifolds, Different accelerator pedal/ cable. Kick down linkage.
A body oil pan.....maybe a A body oil pickup tube.... 90 degree oil filter adapter....
sad to see another slant bite the dust......if it were me, I would slap another slant in its place and go on for some more happy miles :)
