roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,808
- Reaction score
- 3,590
I was happy to read this. I was starting to think the custom grind solid roller I have from IQ52 was a piece of junk cut for a big block Chevy after reading this thread.
If you did, great, if not, great.
People can get a bit diehard when it comes to brands, preferences vary...what works is gold, right? We all have a bit of this in us...I think they call it 'common sense'.lol Well we are just the lucky customers, fortunate enough to have a good experience be it quick turn around, customer service in general... or just by virtue of giving the correct and utmost accurate details of the motor/heads, usage, hp expectation. But it could have been the next company in line that ground your cam and gave the same end result...you'll never know, right?lol Others like to throw in the brand issue..."they're a Chevy shop" or "they're a Mopar only shop"...if they are a REAL shop none of that would matter, it's math+experience...plain and simple and in my opinion the only water those statements hold is in regards to shadow grinders/builders who take the stenciled path... grinding old catalog numbers, which does happen a lot. Thing is...there are variables, be it flaw or advantage in the combo , those numbers on the box by only a few degrees can make or break the performance...hence experience.
Honestly I find myself happy with every custom grind I use, be it Engle, Herbert, Lunati, Schneider etc.. and I'm sure you will too. BTW Lunati gets pricey.
