Do they come with the fender rings and hardware, or do use original stuff?I just have an inexpensive aftermarket one that I put in years ago. It's worked since 1988. I wouldn't spend a ton on it as theses cars are not used every day and so even a cheap antenna will last forever.
Yes they do. Easy.to reach in through the gap between the door and fender to install. Shouldn't take more than an hour.Do they come with the fender rings and hardware, or do use original stuff?
What did you use to plug antenna hole in fender? I'm considering radio delete as I already have dash plate.I just leave mine off. Rather hear the car rumble vs old cheesy music.
That is side mirror delete, I'm not seeing antenna hole filler. Perhaps I missed it.SS & AFX in Arizona market the correct antenna delete
Products - SS and AFX
