whitebomber63
would a 15 x 8 even fit in the rear?? someone school me so i don't buy the wrong size rims lol.
There's probably a few that have done it I bet. I thought I could with my 66 Dart if I could split the gaps with a special offset or some spacers. I didn't want to roll the fender lip. It's a GT car with wheel opening moldings. A little more tricky rolling the lips and you ruin the moldings.If you are lucky 15x8 may fit. I put 15x8 with zero offset and 245/60R15s on one car and they cleared with 1/2" clearance both sides and 1/2" to the springs both sides. No rubbing with plus 1" rear springs. Tried the same wheels and tires on one of my other cars and they were about 1/4" from the fender well on one side and about 3/8" on the other side. Would have rubbed for sure. Guess the fenderwells are a bit wider on one and narrower on the other. So with luck 8" could fit, but don't count on it.
Love those 64 post cars. I was looking for one when I found my 66. I would have to mini tub that bad boy.1964 Dodge Dart with 235/60/15 on 6'' factory steel wheels that I believe are a 3 3/4 backspace. Plenty of room.View attachment 1715355962
You can't go wrong with 7's. They look good and work without issues.thanks for all the info guys, think i am gonna go with the 14 x 7 to be safe. anyone else that has been through this song and dance before feel free to enlightening me.
nice what size wheel you got on the front there, I like the way the offset looks.You can't go wrong with 7's. They look good and work without issues.
Those are stock 14x5.5'snice what size wheel you got on the front there, I like the way the offset looks.
@MikeH, you disagree with my front wheel size?Those are stock 14x5.5's
what size on the rear?? any rear modifiations on that car?? think i might get the 15x7 and raise the car a little bit if i need to... i have coil overs on the rear so i think it might be alittler higher in rear then stock not exactly sure... gonna talk to a friend that has a wheel shop and see if he has anything same size to test fit.Those are stock 14x5.5's
Looks good. Ya a fresh set of springs would probably help.As info, I just mounted up my new set of 15" steelies. Fronts are 15x6, 3.75 BS, tire 215/65/15. They fit but it rubs a little bit at full lock to the right. Not a big deal, I can always back off a hair on a tight right-hand turn if needed. This could easily be just a function of a completely worn out front end that hasn't been rebuilt yet. The rears are 15x7, 4.25 BS, 245/60/15 tires. It fits, but it's all the tire I can get under there with stock suspension and no mods. Clearance in the rear is 1/2" to the spring, and I can get slide my hand fully between the outer tire edge and the fender. I'll get a better picture later if you need one, but here's what they look like.
15x7 with a 4 1/2" back space. No modifications. Pics of your coil overs?what size on the rear?? any rear modifiations on that car?? think i might get the 15x7 and raise the car a little bit if i need to... i have coil overs on the rear so i think it might be alittler higher in rear then stock not exactly sure... gonna talk to a friend that has a wheel shop and see if he has anything same size to test fit.
ill grab a picture of them next time i see the car, it is sitting at my parents house in the valley. don't want the salt air to get to it down here near the beach.15x7 with a 4 1/2" back space. No modifications. Pics of your coil overs?
this helps a ton thanks!As info, I just mounted up my new set of 15" steelies. Fronts are 15x6, 3.75 BS, tire 215/65/15. They fit but it rubs a little bit at full lock to the right. Not a big deal, I can always back off a hair on a tight right-hand turn if needed. This could easily be just a function of a completely worn out front end that hasn't been rebuilt yet. The rears are 15x7, 4.25 BS, 245/60/15 tires. It fits, but it's all the tire I can get under there with stock suspension and no mods. Clearance in the rear is 1/2" to the spring, and I can get slide my hand fully between the outer tire edge and the fender. I'll get a better picture later if you need one, but here's what they look like.
