krazykuda submitted a new Article:
How to Rebuild a Small Block Part 4: Pre Flight Inspection After Machine Shop Before Assembly
Read more about this article here...
This is the first stage for assembling the engine... If you go to a machine shop for your block work, this is where you want to begin... In this chapter I am going to go through inspecting the block after a machine shop to make sure everything was done properly and give some sources...
