I’m going to change my vote to ProMaxx, too. Because we all know this is, after all, called “Drag Truck”. And there’s mention of a trailer used to take it out to the track. So, knowing the progression of where things lead, one day the goal may be 550 to somewhere over the 600+ horsepower limit of the stock block. So go ahead and get heads that will give you room to make use of 260
[email protected] with .600 lift, larger induction, and lower gears. Because like you say so often, the direction changes. And this one may easily turn into the one that you want to go really fast with.
