flathead31coupe
Is there a replacement tire for the mickey thompson indy profile n50 14" tires
I see your nickname is flathead31coupe. Do you have one? Could you share some pictures?Is there a replacement tire for the mickey thompson indy profile n50 14" tires
I built a 31 model a couple years ago, had it in a few car shows..flathead engine three carbs t5 transmission. It was Is wimbleton white..I see your nickname is flathead31coupe. Do you have one? Could you share some pictures?
These are what came on it when I got it fourteen inchThe widest 14" tire I've seen in years is a 245/60R14 which is rated for a 7-8.5" wide rim; so if you're trying to find a tire for an existing set of rims you have, that's about the limit. 25.6" diameter, 8.2" tread width, 9.8" section width.
How wide are the rims?
Iam no sure...How wide are the rims?
Probably 10" wide rims. You really can't fit N50's on anything narrower.My brother had a duster in the 70s and had n or m 50s he can't remember the width or back space...but did say you could stand on the rear tire edge and wash the top of the car..just jacked up in the back no suspension mods...thinking of doing the same thing..not sure what rim specs to get... They were cragers
