1967 Barracuda Wing Windows
boosted
Life Needs Air
Muscogee/Harris County GA
I am putting them in for the first time since I had the car as they where out when I bought it. I have the two front connections done. One bolt and one nut on the lower stud. But at the bottom of the long chrome bar that goes into the door is a round part that looks like a door hinge minus the pin. Then ther is a plate in the bottom of the door with the same thing. how is this thing connected at the bottom and with what if it is. I am not a glass man for sure.
You're talking this hole(far left in pic)?
There is a nut accessed from the bottom. Depending on the year, what the nut attaches to may have a hex head on top you can put a wrench on. If not hex, a small set of vise grips to hold it. Soak the pi$$ outta it.
More pics. 2nd from inside door with "adjuster" and nut removed. You can see the hole it goes thru.
Get a FSM, you will need it.
Last pic shows adjuster installed and vent window/frame removed.
These are for 2nd gen cudas.
Yep I see it. Your missing the adjustment stud pictured in the pics Steve posted.
When you get the studs be sure to use the short piece of foam that goes between the bracket and stud or it will rattle and drive you crazy.
I have to ask does the window stop limit up or down? Do i install it with window all the way up or all the way down? Thank you again for the help.
