[FOR SALE] 1967 Barracuda
rmicciolo
Roslyn
Rating - 0%
0   0   0
1967 barracuda 6cyd needs resto typical rust on fender door and quarter, frame rails trunk and floor pan looks good
440 30 over street strip everything new but block and crank steel crank 10/10 eagle h beam rods rated 1200hp, 10 1/2 pistons, trick flow 240 heads, trick flow matching manifold, holley 950hp carb,comp cams hdy roller 549.544 lift 242, 248 duration comp roller lifters 3/8 push rods, 440 source 1,5 roller rockers, milidon 6 qt oil pan with pick up and windage tray, melling m-63hv pump. pro billet distributor, 1 wire altenator electric water pump mini starter plumbed nitrous complete engine never fired up, mid 70 440 truck engine 2- 727 trans with 10inch coverters need to be gone thru narrowed 8 3/4 rear 42,8 742 housing with 4.30 gears dana powerlok, 30 spline axles with 4 link bars weld star 15x12 3 1//2 backspacing 5 on 4.5 and weld star 15x3 1/2 with mickey Thompson 15.5 x29x15 2 inch tti a body headers new hurst shifter msd 7al2 used center console will sell all as packaged deal $10,000.00 or obo
Figures the other side of the world eh ! Theres a Roslyn in Washington that isn't that far from the border . Thanks anyway.
