[FOR SALE] 1968 340 short block everything cleaned and painted
moparraceman
mansfield ohio
have for sale late 1968 block guess actually used in 1969 cars dart 340 275 hp std bore been cleaned at machine shop , and checked , i painted it ,stock steel crank std,std as is the block std bore have the stock 10.5 .1 pistons . have a comp double roller timing chain and gears ,front cover,windage tray , water pump,fuel pump ,i have new freeze plug kit,new cam bearings,rod and main bearings,and new rings ALSO STOCK RECONDITION RODS WITH NEW ARP BOLTS NO OIL PAN OR OIL PUMP do have a dist drive gear nice shape .$1750 nice pc pick up ohio thanks
So what is the VIN on the block? I am still looking for my original block for my 69 GTS that was probably cast in 1968. It looks like what I can see on the date code that it is in reality a block that was used in a 1969 car.
L = Dodge Dart
M = Medium
23 = 2 Door Hardtop
P = 340 275HP 1-4BBL 8 CYL
9 = 1969
Breaks down to be for a 69 Dart.
have for sale late 1968 block guess actually used in 1969 cars dart 340 275 hp std bore been cleaned at machine shop , and checked , i painted it ,stock steel crank std,std as is the block std bore have the stock 10.5 .1 pistons . have a comp double roller timing chain and gears ,front cover,windage tray , water pump,fuel pump ,i have new freeze plug kit,new cam bearings,rod and main bearings,and new rings ALSO STOCK RECONDITION RODS WITH NEW ARP BOLTS NO OIL PAN OR OIL PUMP do have a dist drive gear nice shape .$1750 nice pc i have for extra money new set of std bore seal power piston 11 to 12.5 -1 cr depending on cc of head $175. also brand new comp mech cam and seal power solid lifters[if you want more power ] # 20-231-4 it has 520 valve lift at .050 244-252 duration never been out of box $250. pick up ohio thanks EVERYTHING LISTED $2000 NEED TO SELL PICKUP OHIO
Where are you located in OH?
Guys , please, lets do this talk in a privet message , easy peazzy
