AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,084
- Reaction score
- 12,432
Yes I think 4.56s are too much, because of the way it affects streetability.Thanks for the replies... AJ do i think 4.56 gears would b to much? Also if I stay with the fuel injection do u think I would see any gains with the Hughes f.i. air gap set up? Would it be worth it or just keep the the stock kegger? I think it would be worth it 2 drop the 5.9 in there? Pretty much a direct swap and I can keep the f.i. etc... Would also put a converter in there with the motor swap. Thanks again
Firstly; the KD at 30 mph becomes ~4400 and basically you have no place to go cuz the tires will light up,and in a split second your engine will be at redline, and the governor will be calling for an upshift.If it doesn't spin, 4800 will be 33mph in first. But if you stay in second, the Rs will only be ~2600... so don't be expecting to be picking up much speed any time soon. To get around that you;d need more cam, more cylinder pressure and more rpm.
Secondly; 60mph will be ~5200 in second, about 400/500 rpm past the power-peak, and firmly on the declining side.So you are gonna need a bigger cam to get back to optimum; and that is at least two sizes, so your cylinder pressure is going, going.......
Thirdly; 65mph=2540 in loc-up,11% higher than 4.10s and so ~ 6% increase in steady-state fuel consumption.
Fourth; the effective-starter gear becomes 4.56x2.45x24/27x1.05=10.43;with an instantaneous ~18/1 at zero mph. This 10.43 starter is waaay more starter than you need in day-to-day operation, and your trans will only be in it for a second or two, whenever you take off, when you are driving normally. But, I do think the rest of the gears will be nice around town, and whenever just poking around. So if you see a cam in your future, then with the 4.56s you would be ready.
So, if you want to ditch the Keg then I recommend the 5.9 as a way of getting the low-rpm torque back, and then you can run a carb. And then you won't need the 4.56s.... nor the 4.10s..... lol. Ima thinking 3.91s, a 2800TC, and a 228* cam, with lots of cylinder pressure. If you want to keep the current cylinder pressure, well then back to the 4.10s and no cam. Or maybe a 220 fast-rate, solid; it kindo depends on the current pressure.
The 5.9 would be my pic, but the 255/60-15s would be history.Then it's like Rumble says,the stock cam leaves a lot of rpm in the garage. And rpm is power. So your 5.9 would need the 1-2-3 punch of more cam,better air-flow, and restore at least some cylinder pressure.Now the 4.56s are making sense. And if you don't restore the cylinder pressure, she'd want a bigger TC.
And around and 'round it goes.
Ok I changed my mind. I'd like to keep the 5.2 untouched. So I'll take 10% more gear and 10% taller tires, thanks; so 4.56s and fat 29s, oh, and ladder bars. oh and dual exhaust. My zero to 60 is coming along nicely now so.....
So, next, I want a fast-rate solid lifter cam, headers , cold air, some programming........ and a bigger TC..
I guess about now my brakes are getting left behind, so those will need to go on the to-do list
But IIRC , at this level, Ima gonna need to ditch the electronics, so now I need a carb and intake, and a proper ignition system.
And round and round it goes.
But hey the chassis is about ready now, so Ima thinking 5.9 time. Make mine a stroker... lol.Ima thinkin' that 4-something is gonna need some new heads, a bigger cam again,and a new TC... again.
Honey.. I know you said you wanted a baby but I need another year...... maybe two.
