65CudaDude
Active Member
would it be possible to bore a 273 to a 318?
Why would you want to?would it be possible to bore a 273 to a 318?
I'd tade our swapped in 318 we have presently for the original 273 anyday!
But on the otherhand I am kinda old, slow, not too bright, and like things stock!
Don't listen to me just rambling drinking coffee readin the morning FABO!
Good luck with your project!8)
Your 273 can be worked over to put out much more than the 318. Over bore by .040 brins you to an even 300 CI. Camcraft will grind a cam for you with solid lifters for about $200.00 total and a little carburetion will get you some impressive performance.
