[FOR SALE] 340/360 parts
cowest432
have the following for sale as lot,,, 340 forged crank, checked for cracks, ok,, x heads checked for cracks,,ok,,needs valve seats,,all, 360 short block was running when pulled around march,,360 heads 202 intakes,, broke a rocker shaft bolt,, 110-115 spring psi,,were tanked but never had bolt removed,, need to go through these,, 340 oil pan,, 8 qt pan for 340 have no idea what make,, 69 340 pistons and rods,,x-tra set forged rods,,8 new OEM 340 pistons low comp both stock size,, duel point after market dist,, PICK UP ONLY,, ASKING 750,, ORANGE CO NY 12543
do you still have the green oil pan? if so how much? thanks jeff
