have the following for sale as lot,,, 340 forged crank, checked for cracks, ok,, x heads checked for cracks,,ok,,needs valve seats,,all, 360 short block was running when pulled around march,,360 heads 202 intakes,, broke a rocker shaft bolt,, 110-115 spring psi,,were tanked but never had bolt removed,, need to go through these,, 340 oil pan,, 8 qt pan for 340 have no idea what make,, 69 340 pistons and rods,,x-tra set forged rods,,8 new OEM 340 pistons low comp both stock size,, duel point after market dist,, PICK UP ONLY,, ASKING 750,, ORANGE CO NY 12543
