So, what block does our OP have? He stated a 4.160 bore all ready.
That is the ultimate question.
Oh, ok. I still think its a 361 B block though
hmm possible. very possible.
Not so;
X blocks are NOT limited to standard production block limitations.
Current-ish, are they even around anymore?!?!?!
LOL! NOT!
How did he get X heads on a 361 block to overheat it? The 340 bore spacing is 4.460 and with that overbore, you end up with .300 between the cylinder for a fire ring of .150 for each cylinder? Does that jive? Show us a pic of the shared cylinder wall with a dime on it.Oh, ok. I still think its a 361 B block though
could be why its over heating......How did he get X heads on a 361 block to overheat it? .
Okee,Okee,, I go home now.. my 340 runs and doesn't overheat...
I aint arguing with you man, when I said my 340 runs and doesn't overheat, I was effectively signing off and saying "do what you want, I really don't give a **** as long as my car runs" the information is out there, do some research and make your own decisions.So does my 340, and it's .060" for a bore of 4.1". I've seen plenty of Mopar small blocks go more than .030" without any issues at all. To say .030" is the "max" is just silly. I mean, I don't doubt that there are core shifted blocks out there that can only go .030" safely. Heck there may even be ones that won't go .030", there are some pretty badly core shifted examples running around. But .030" over as a max safe bore for all of them? Hogwash.
As for sleeves, perfectly fine, they work great. It's just an extra expense. If it's the original engine on a valuable car, it totally makes sense. If it's just some small block, find another one. The 340's aren't getting any easier to find though, so if you really want to keep the 340 it could be worth it. Some of the prices for 340 blocks I've seen lately would more than pay for sleeving all 8 holes in a block you already had.
I aint arguing with you man, when I said my 340 runs and doesn't overheat, I was effectively signing off and saying "do what you want, I really don't give a **** as long as my car runs" the information is out there, do some research and make your owners n decisions.
Does this mean a block could be over bored extensively and just sleeved to what you want it to be?
Yes. PAW used to sell std bore 340s that had 8 sleeves. They may have been better than new as the sleeves were uniform and perhaps of better metallurgy. IDK what the sleeve thickness was but they do sell 4.000 and 4.040 sleeves.Does this mean a block could be over bored extensively and just sleeved to what you want it to be?
That's what I'm talking about- or a 400 SBC 4.1X5 bore, where there are piston selections.So here is a thought, question, could you take a standard 340 and re-sleeve it to be taken out to a 4.22 bore?
Interesting.... With a 4.46 bore-center-to-bore-center distance, that would leave .240 inches or less for sleeve walls and coolant gap. That would take out the cast bore walls for all practical purposes; they would be gone, or what might be left would just crumble and break out, and leave the sleeves supported at top and bottom only. I would imagine they would have to be welded top & bottom to seal off the water jacket, and/or have the cooling jacket filled. And with a max wall thickness of under .120" each.....not counting any interference with the valley or outside block surfaces. Sounds like a challenging proposition....but knowing hot-rodders, it may well have been done!So here is a thought, question, could you take a standard 340 and re-sleeve it to be taken out to a 4.22 bore?
Only if the block could be safely bored to 4.483. The wall thickness for these sleeves are .125. add .250 to the ID and the OD is 4.483 Melling CSL2258: Cylinder Sleeve Bore: 4.2330" | JEGSSo here is a thought, question, could you take a standard 340 and re-sleeve it to be taken out to a 4.22 bore?
I still think the OP is doing something wrong
A 4.160 bore without custom pistons and only running a 262 cam ? Don't add up
Did You run/have the overheating before You tossed the X heads on? Cooked rings are not the cause of overheating, they would be the result.Hi guys, I picked up a 73 Dart Sport last year with a 340 in it. I opened it up and just did a top end refresh and tossed on set of x-heads. I had over heating issues all summer, tossed in a new 3 core rad, new fans and multiple thermostats. Still had issues. I just pulled this engine apart and found that he rings were cooked. before ordering new rings I wanted to double check the piston size and found that they were at 4.160..... IS THIS MY OVER HEATING ISSUES???? CAN THS ENGINE OPPERATE AS A DRIVER BORED THIS MUCH??????
As far as I know;The head gaskets only fit one way, unless you either pull the line-up pins or make new holes.You would also need to run a Fel-Pro 1008 gasket w/a 4.180 bore if indeed that is the bore.............dumb question, but You didn't install the head gaskets reversed &
block the cooling passages did You ?...........................
