I'm with the 2 harsh and honest opinions, I laos been down that road a tad, but if that's what he wants.......
68FormulaS340, post up the old specs if ya remember them or gottem.
You to Physixx.
WIth just 340 cubes, I figure a cam duration @ .050 starting with 250 would be a min, single plane, ported heads, large tube header, big stall to match with at least ....4.30's?
OH crap, he has a vert, damn, I missed that. Extra weight. OK, more cam and gear.
Go roller duration @ .050 260 and port for 600 lift and 4.88's
That'll getcha going.
Ok these are some of the specs on my engine.
Its a standard bore 340. (My original engine)
Cam: Crower Solid Street Roller. #3146 (This is the old 3164 grind from 1988 the new grind with the same # has less lift and duration.)
RPM power range 3200-7200 (redline 7800+)
Grind Lobe Center: 290R/112 degrees
Advertised Duration: intake-290, exhaust-294
Duration at .050": intake-251, exhaust-256
Gross Lift: intake-.550", exhaust-.555"
Holley 800DP
Victor 340 intake.
Heads: professionally ported and flowed original X heads.
Harland Sharp rockers
Hooker Super Comps into 3" mandrel bent exhaust
Extensively reworked/polished stock rods.
Balanced…. And so on…
Basically a precision, high compression (about 12 to 1) and high RPM build. Regularly saw 8000rpm at the track.
And so on, but that is the basic engine stuff.
And then…… We get into all the other crap that you need…. custom built clutch, sub frame connectors, scatter shield, battery relocation, dana 60, electric water pump, electric fans, drag shocks, alignment for track use, SS springs…..
Your basic pain in the *** "street car".
Oh…. And then came the great day the car hit the 11s… It was kicked off the track and told not to come back without a cage…..
