Woods74
Broke Senior
No, I just think your jumping the gun, making classic mistakes on building too much cam, maybe its me or just your personality. Your like a Jack Russel terrier, BOING BOING BOING, ever hear slow down to go fast?
I ran a KB107 360 w/508 Purple shaft and it was the happiest motor I've ever owned. The heads had 2.02 valve w/bowl work only. Low Gear 904. Consistant 11.70 @ 115 @ 3050 ft. Best pass ever was 11.49 @116 @ Speedworld in Phoenix. It had a 1.49 60'. 3000 lbs Duster T/A convertor, 4.56 Gears and 13x31 Slicks. The motor has been in my sons street car for years and got to the Final 4 Pinks Allout Tucson in 2007 running 12.50's. later matt
Car 1972 Dart
Weight 3350 w/driver
Gears 3.91
Trans 727,reverse man.valve body,3500 Coan conv.
Tires 28x10 Hoosiers
Suspension8 3/4 S/S springs,long drag shocks
Engine 1974 360
Pistons K.B 107 +030
Rods stock with ARP bolts
Crank Stock .010/.010
Heads Stock J heads 1.88/1.60 valves
Cam MP 508/292
Intake Edlebrock TM-5
Carb Holley 750 DP 80/82 jets
E.T 12.02
MPH 112
RPM/Traps 5700
60 foot 1.62
for certain engine combos the 188 valve head is better
That may be,for certain engine combos the 188 valve head is better
